But It Worked Yesterday - When Websites Break Without Warning
Your website can suddenly stop working even when you haven't changed a thing. From software updates and server migrations to security firewalls, we explore some of the behind-the-scenes changes that can cause unexpected website issues.
Photo by Vitaly Gariev on Unsplash
If you've ever opened your website only to discover that something isn't working, you're probably familiar with the frustration that follows. Maybe your homepage suddenly displays an error message, a plugin stops functioning, or you find yourself unable to log into your dashboard.
And the first question that probably comes to mind is, "Why? Everything was working fine yesterday!"
It's a question we hear fairly often on the Reclaim Hosting support team, and it's a perfectly reasonable one. After all, if you haven't made any changes to your website, why would something suddenly stop working?
The answer is that even when you're not actively making changes to your website, plenty of things can still be happening behind the scenes.
Your Website Doesn't Exist in a Bubble
It's easy to think of a website as something relatively static. You install WordPress, Omeka, or another application, build your site, and expect it to keep working unless you change something.
But websites depend on a lot of moving parts. There's the application itself, the plugins and themes it uses, the PHP version running on the server, the database, and the server environment that supports everything.
There are also external services, DNS settings, and security systems that affect how visitors connect to your site.
Any one of these components can change independently of the others. And sometimes, a change in one place can cause an unexpected problem somewhere else.
Let's look at a few examples.
Software Updates Can Cause Unexpected Problems
Keeping applications updated is an important part of maintaining a secure website. But occasionally, an update can introduce a compatibility issue.
For example, a WordPress plugin might release an update that conflicts with another plugin or with your site's theme. Something that worked perfectly before the update might suddenly stop functioning.
Sometimes the update happens automatically, meaning you might not even realize anything has changed.
This doesn't mean you should avoid updates. Quite the opposite. Outdated software can introduce security vulnerabilities and other problems. But it does mean that even routine updates can sometimes require a little troubleshooting.
The Server Environment Changes
Another less obvious point is that the server hosting your website needs regular maintenance and updates.
At Reclaim Hosting, we've recently been working through PHP version updates and server migrations. Both are important parts of keeping our hosting environment secure, supported, and running efficiently.
But changes to the server environment can occasionally reveal compatibility problems in older applications.
For example, an application that was designed to run on an older PHP version might not work correctly with a newer version. Sometimes this results in a visible error message. Other times, certain features stop working as expected.
Similarly, moving a website to a newer server can expose outdated configurations, file permission issues, or other dependencies that weren't causing problems in the previous environment.
These issues aren't necessarily a sign that something went wrong with the migration or update. Sometimes an older configuration was simply relying on behavior that the newer environment no longer supports.
Security Tools Can Cause Problems
Security is another area where changes can happen without you realizing it.
Web hosting providers use firewalls and other security tools to help protect websites against malicious traffic, automated attacks, and suspicious requests.
These tools are constantly evaluating activity and may receive updated rules to address new threats.
Occasionally, however, legitimate activity can be mistaken for something suspicious.
You might suddenly find that you're unable to save a page in WordPress, upload a file, or access part of your website. You haven't changed anything, but a security rule may be interfering with the request.
Once identified, these issues can usually be addressed by reviewing the relevant security logs and adjusting the rule or configuration as appropriate.
Sometimes It's A Setting or Service
Of course, not every unexpected website problem comes from an update or a security rule.
A hosting account might reach its disk storage limit. A domain's DNS records might be changed or misconfigured. A third-party service your website depends on might experience an outage.
Even your browser can occasionally contribute to the confusion by displaying an outdated cached version of a page.
The important thing to understand is that a website involves more than just the content you see on the screen. There are quite a few systems working together to make everything function.
What To Do When Something Breaks?
Take note of what you're seeing. Is there a specific error message? Does the entire site fail to load, or is it just one feature? When did you first notice the issue?
When you contact our support team, those details can be incredibly helpful. Even something as simple as a screenshot or the exact URL where the problem occurs can help us narrow down what's happening.
From there, we can investigate the hosting environment, review error logs, check for recent changes, and help determine where the problem might be coming from.
A Website Is Always Evolving
The reality is that websites aren't quite as static as they appear. Even if you haven't touched yours in weeks or months, the technology supporting it continues to evolve.
Updates, security improvements, and infrastructure changes are necessary parts of keeping the web running. And while they occasionally introduce unexpected challenges, they're also what help keep websites secure, reliable, and accessible over time.
So the next time you find yourself saying, "But it worked yesterday!" remember that something may have changed behind the scenes, and if you're not sure what that something is, we're always happy to help you figure it out.
